Publisher: Electronic Arts
Crysis is seen by many as the poster boy for DirectX 10 and it will make your system cry, quite literally – it’s a monster! It doesn’t come as much of a surprise then, that the graphics are something special – they’re above and beyond anything we’ve ever seen in a PC game.
We tested the game using the 64-bit executable under DirectX 10 mode with the 1.21 patch applied. We used a custom timedemo recorded from the Laws of Nature level which is more representative of gameplay than the built-in benchmark that renders things much faster than you're going to experience in game. We found that around 27-33 fps in our custom timedemo was sufficient enough to obtain a playable frame rate through the game. It's a little different to other games in that the low frame rates still appear to be quite smooth.
In addition to testing under DirectX 10 with all quality details set to High, we feel it's about time hardware should be able to handle the game with the in-game settings tuned to Very High. The game has been out for at least a year now, so it's time for hardware manufacturers to catch up with the software.
We forced 8x anisotropic filtering in the driver menu as there is currently no support for it in game and tested at 1,280 x 1,024, using 0x, 2x and 4x anti-aliasing, 1,680 x 1,050 using 0x and 4x anti-aliasing, 1,920 x 1,200 using 0x and 2xAA and 2,560 x 1,600 with 0xAA. By extensively testing using anti-aliasing in very high resolutions in conjunction with Very High quality in-game settings, we'll be pushing even the bleeding edge hardware on test to the limit.
Nvidia GeForce GTX 285 1GB
Palit GeForce GTX 275
Nvidia GeForce GTX 275 896MB (ForceWare 185.63)
Nvidia GeForce GTX 275 896MB (ForceWare 182.50)
ATI Radeon HD 4890 1GB
Nvidia GeForce GTX 260-216 896MB
ATI Radeon HD 4870 1GB
Frames Per Second
Frames Per Second
Frames Per Second
Frames Per Second
Frames Per Second
Frames Per Second
Frames Per Second
Frames Per Second
There's always very slight differences between results in any benchmark run, creating a statistically negligible difference between the performance of the Palit GTX 275 and our Nvidia stock model. Still, performance itself, especially using the new 185.63 beta driver is excellent and comfortably beats out the competing Radeon HD 4890 with Catalyst 9.4 beta at every resolution and anti-aliasing setting, especially at the lower resolutions where the margin of victory is over twenty percent!
